Ir para o conteúdo principal
AlphaSmart Pro Lithium Coin Battery Replacement
O que você precisa
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 2 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 3 %32
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, imagem 2 %32
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, imagem 2 %32
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, imagem 2 %32
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
Conclusão
Katy Beth Culp
Membro desde: 10/13/14
1 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-1, Benson Fall 2014 Membro de Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 1,107
