Introdução
Prerequisites 1. Follow the procedure in Before working inside your computer.
O que você precisa
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
Disconnect the Tron light cable from the system board.
Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
Open the latch and disconnect the display cable from the system board.
Disconnect the Alienhead LED cable from the system board.
Peel the display cable from the system board and remove the display cable from the slot on the system board.
Lift the system board Mylar next to the left fan to access the power-adapter port.
Remove the two screws (M2x4) on the power-adapter port-bracket that secures the power-adapter port bracket to the systemboard.
Lift the power-adapter port-bracket off the system board.
Disconnect the power-adapter port-cable from the system board.
Peel and lift the power-adapter port, along with its cable, off the system board.
Uma outra pessoa concluiu este guia.
