Introdução
Prerequisites 1. Follow the procedure in Before working inside your computer.
O que você precisa
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Disconnect the battery cable from the system board (applicable only if not disconnected earlier).
Remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
Lift the battery off the palm-rest and keyboard assembly.
Open the latch and disconnect the keyboard-backlight cable from the keyboard-controller board.
Open the latch and disconnect the keyboard cable from the keyboard-controller board.
Open the latch and disconnect the keyboard-controller board cable from the keyboard-controller board.
Remove the screw (M2x2) that secures the keyboard-controller board to the palm-rest and keyboard assembly.
Remove the keyboard-controller board off the palm-rest and keyboard assembly.
