Ir para o conteúdo principal
Alienware P18G M14X R1 RAM Replacement
O que você precisa
  1. Alienware P18G M14X R1 RAM Replacement, Back Cover: passo 1, imagem 1 %32
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 RAM Replacement: passo 2, imagem 1 %32
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 RAM Replacement: passo 3, imagem 1 %32
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Unscrew the two 6.35 mm using the PH1 screw driver.
  5. Alienware P18G M14X R1 RAM Replacement: passo 5, imagem 1 %32 Alienware P18G M14X R1 RAM Replacement: passo 5, imagem 2 %32
    • Lift the plate and remove it to uncover the RAM sticks.
  6. Alienware P18G M14X R1 RAM Replacement: passo 6, imagem 1 %32
    • Push outward on the prongs that secure the RAM stick in the slots.
    • After releasing the prongs the rams stick will rise up.
  7. Alienware P18G M14X R1 RAM Replacement: passo 7, imagem 1 %32
    • Be very gentle in this step, making sure to not damage anything.
    • Pull the RAM stick out of its housing.
  8. Alienware P18G M14X R1 RAM Replacement: passo 8, imagem 1 %32
  9. Alienware P18G M14X R1 RAM Replacement: passo 9, imagem 1 %32
    • Pull the second ram stick out of its housing.
Conclusão
Andonaq Grozdani
Membro desde: 03/01/18
892 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,039
