Ir para o conteúdo principal
Alienware P18G M14X R1 Optical Drive Replacement
O que você precisa
  1. Alienware P18G M14X R1 Optical Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Optical Drive Replacement: passo 2, imagem 1 %32
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Optical Drive Replacement: passo 3, imagem 1 %32
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Optical Drive Replacement, Battery: passo 4, imagem 1 %32
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Optical Drive Replacement: passo 5, imagem 1 %32 Alienware P18G M14X R1 Optical Drive Replacement: passo 5, imagem 2 %32
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Optical Drive Replacement: passo 6, imagem 1 %32
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Optical Drive Replacement, Optical Drive: passo 7, imagem 1 %32
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Optical Drive Replacement: passo 8, imagem 1 %32
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Optical Drive Replacement: passo 9, imagem 1 %32
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
Conclusão
Andonaq Grozdani
Membro desde: 03/01/18
892 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 453
