Introdução
This guide will show you how to replace the hard drive for the Alienware P18G M14X R1. To replace the hard drive you will need to remove the battery and the Optical drive.
O que você precisa
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
6 outras pessoas executaram este guia.
