Ir para o conteúdo principal
Alienware M17x P01E Cooling Fan Replacement
O que você precisa
  1. Alienware M17x P01E Cooling Fan  Replacement, Battery: passo 1, imagem 1 %32
    • Please power off the computer and deplete the battery before attempting the following step.
  2. Alienware M17x P01E Cooling Fan  Replacement: passo 2, imagem 1 %32 Alienware M17x P01E Cooling Fan  Replacement: passo 2, imagem 2 %32
    • Press down on the battery latch and slide it to the left.
    • Lift the battery out once it pops out.
  3. Alienware M17x P01E Cooling Fan  Replacement, Compartment Door: passo 3, imagem 1 %32
    • Loosen the two silver Phillips #1 screws.
    • The screws are held to the compartment door by a washer and cannot be removed.
  4. Alienware M17x P01E Cooling Fan  Replacement: passo 4, imagem 1 %32 Alienware M17x P01E Cooling Fan  Replacement: passo 4, imagem 2 %32
    • Use your hand to gently lift and remove the compartment door.
  5. Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: passo 5, imagem 1 %32 Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: passo 5, imagem 2 %32 Alienware M17x P01E Cooling Fan  Replacement, Cooling Fan: passo 5, imagem 3 %32
    • Loosen the three black Phillips #1 screws.
    • The screws are held to the fan by a washer and cannot be removed.
  6. Alienware M17x P01E Cooling Fan  Replacement: passo 6, imagem 1 %32 Alienware M17x P01E Cooling Fan  Replacement: passo 6, imagem 2 %32
    • Use your hand to gently lift the fan from the laptop.
    • Careful not to pull too hard on CPU fan cable.
Conclusão
Kevin Palacios
Membro desde: 09/17/18
169 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G2, Bruce Fall 2018 Membro de CSU Fullerton, Team S2-G2, Bruce Fall 2018
CSUF-BRUCE-F18S2G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 557
