Ir para o conteúdo principal
Alienware M17x Hard Drive Replacement
O que você precisa
  1. Alienware M17x Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Alienware M17x Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x Hard Drive Replacement: passo 4, imagem 1 %32 Alienware M17x Hard Drive Replacement: passo 4, imagem 2 %32
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
  6. Alienware M17x Hard Drive Replacement: passo 6, imagem 1 %32 Alienware M17x Hard Drive Replacement: passo 6, imagem 2 %32 Alienware M17x Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the eight 3.5 mm Phillips #0 screws.
    • Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 2,361
