Ir para o conteúdo principal
Alienware M17-R1 Screen Lock Assembly Replacement
O que você precisa
    1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: passo 1, imagem 1 %32
      • Open the screen until it is flat.
      • Ensure that the surface you are working on can support both the screen and the base of the laptop.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17-R1 Screen Lock Assembly Replacement: passo 2, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 2, imagem 2 %32
      • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
      • Support the screen from the bottom to make it easier to remove the screws.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17-R1 Screen Lock Assembly Replacement: passo 3, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 3, imagem 2 %32
      • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
      • Be careful not to break the face of the screen when lifting it.
      Pergunte ao FixBot
      Comentar
    4. Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 2 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 3 %32
      • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
      • Pull the assembly grip away to remove it.
      • Remove the two 5 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Alienware M17-R1 Screen Lock Assembly Replacement: passo 5, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 5, imagem 2 %32
      • Push in the assembly towards the spring.
      • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
      • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
      Pergunte ao FixBot
      Comentar
    6. Alienware M17-R1 Screen Lock Assembly Replacement: passo 6, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 6, imagem 2 %32
      • If the spring is defective, slide it off the end of the assembly and replace it.
      Pergunte ao FixBot
      Comentar
Conclusão
William Davis
Membro desde: 10/09/18
323 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 748
