Ir para o conteúdo principal
Alienware M17-R1 RAM Replacement
O que você precisa
  1. Alienware M17-R1 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 RAM Replacement: passo 2, imagem 1 %32
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Place laptop down on a hard flat surface to begin the disassembly.
  4. Alienware M17-R1 RAM Replacement: passo 4, imagem 1 %32 Alienware M17-R1 RAM Replacement: passo 4, imagem 2 %32
    • Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
  5. Alienware M17-R1 RAM Replacement: passo 5, imagem 1 %32
    • Once the cover is removed, locate the RAM compartment to begin the replacement.
  6. Alienware M17-R1 RAM Replacement: passo 6, imagem 1 %32 Alienware M17-R1 RAM Replacement: passo 6, imagem 2 %32
    • After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
    • The card will pop up once it has been released and can be removed.
  7. Alienware M17-R1 RAM Replacement: passo 7, imagem 1 %32
    • To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
Conclusão
LXA054
Membro desde: 10/09/18
337 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 641
