Ir para o conteúdo principal
Alienware M17-R1 CPU Cooler Replacement
O que você precisa
  1. Alienware M17-R1 CPU Cooler Replacement, Battery: passo 1, imagem 1 %32
    • Push the slider until the battery is released from its socket.
  2. Alienware M17-R1 CPU Cooler Replacement: passo 2, imagem 1 %32
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
  3. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: passo 3, imagem 1 %32
    • First begin by placing the laptop on a hard flat surface.
    • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
  4. Alienware M17-R1 CPU Cooler Replacement: passo 4, imagem 1 %32
    • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
  5. Alienware M17-R1 CPU Cooler Replacement: passo 5, imagem 1 %32
    • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
    • Screws 1 through 4 are integrated into the cooler and will come all the way out.
  6. Alienware M17-R1 CPU Cooler Replacement: passo 6, imagem 1 %32
    • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
Conclusão
LXA054
Membro desde: 10/09/18
337 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 724
