Pular para o conteúdo principal
Introdução
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
  1. First, take off the battery by moving the latch to the left and pulling it up.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Unscrew the two screws indicated
    • Unscrew the two screws indicated
  5. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Conclusão
6 outras pessoas concluíram este guia.
Gabe
Membro desde: 09-04-2010
8.074 reputação
3 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
286 Membros
808 Guias de autoria
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 23,967
