Ir para o conteúdo principal
Alienware M15x Optical Drive Replacement
O que você precisa
  1. Alienware M15x Optical Drive Replacement, Remove the Screw: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before performing these procedures, turn off the computer, disconnect the AC adapter from the electrical outlet and the computer, disconnect the modem from the wall connector and the computer, and remove any other external cables from the computer.
    • Remove the screw that secures the optical drive to the computer base.
  2. Alienware M15x Optical Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Make sure the Center Control Center, Keyboard, Palm Rest, Display Assembly, Magnesium Cover and Input/Output Board is removed.
    • Remove the three screws that secure the optical drive to the computer base.
  3. Alienware M15x Optical Drive Replacement, Removing the Optical Drive: passo 3, imagem 1 %32
    • Lift the optical drive out of the computer.
    • Remove the five screws that secure the optical drive to the optical-drive bracket and lift the optical-drive bracket out.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 938
