Ir para o conteúdo principal
Alienware M15x Hard-Drive Replacement
O que você precisa
  1. Alienware M15x Hard-Drive Replacement, Turn the Computer: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Turn the computer over.
  2. Alienware M15x Hard-Drive Replacement, Sliding the Battery: passo 2, imagem 1 %32
    • Slide the battery latch to the unlock position as shown.
  3. Alienware M15x Hard-Drive Replacement, Removing the Battery Pack: passo 3, imagem 1 %32
    • After the Battery Pack pops up, remove the Battery Pack.
  4. Alienware M15x Hard-Drive Replacement, Aligning the Battery Pack Tabs: passo 4, imagem 1 %32
    • Align the battery pack tabs with the slots in the battery bay.
  5. Alienware M15x Hard-Drive Replacement, Pushing the Battery Pack: passo 5, imagem 1 %32
    • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
  6. Alienware M15x Hard-Drive Replacement, Loosen the Screws: passo 6, imagem 1 %32
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Loosen the four captive screws that secure the hard-drive assembly.
  7. Alienware M15x Hard-Drive Replacement, Lifting the Hard-Drive Assembly: passo 7, imagem 1 %32
    • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
  8. Alienware M15x Hard-Drive Replacement, Remove the Screws: passo 8, imagem 1 %32
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  9. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: passo 9, imagem 1 %32 Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: passo 9, imagem 2 %32
    • Lift the hard drive out of the hard-drive bracket.
  10. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: passo 10, imagem 1 %32 Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: passo 10, imagem 2 %32
    • Disconnect the interposer from the hard drive.
  11. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: passo 11, imagem 1 %32 Alienware M15x Hard-Drive Replacement, Connecting the Interposer: passo 11, imagem 2 %32
    • Connect the interposer to the NEW hard drive.
  12. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: passo 12, imagem 1 %32 Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: passo 12, imagem 2 %32
    • Place the hard drive in the hard-drive bracket.
  13. Alienware M15x Hard-Drive Replacement, Replace the Four Screws: passo 13, imagem 1 %32
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  14. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive Assembly: passo 14, imagem 1 %32
    • Place the hard-drive assembly in the hard-drive bay.
  15. Alienware M15x Hard-Drive Replacement, Aligning and Tightening the Screws: passo 15, imagem 1 %32
    • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 482
