Introdução
This guide provides instructions on how to upgrade or replace the hard drive in an Alienware M15x.
O que você precisa
Remove the battery by sliding the latch to the left and pulling the battery up.
Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
Quase terminado!
Conclusão
