Ir para o conteúdo principal
Alienware M15x Hard Drive Replacement
O que você precisa
  1. Alienware M15x Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Alienware M15x Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Alienware M15x Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: passo 2, imagem 1 %32 Alienware M15x Hard Drive Replacement, Compartment Door: passo 2, imagem 2 %32
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: passo 3, imagem 1 %32 Alienware M15x Hard Drive Replacement: passo 3, imagem 2 %32 Alienware M15x Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: passo 5, imagem 1 %32 Alienware M15x Hard Drive Replacement: passo 5, imagem 2 %32
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: passo 6, imagem 1 %32 Alienware M15x Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: passo 7, imagem 1 %32
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
Conclusão
David Sann
Membro desde: 01/22/18
111 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G3, Banghart Winter 2018 Membro de Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 883
