Introdução
Use this guide for help on removing the compartment door. This is necessary for other replacement guides such as the GPU and the hard drive.
O que você precisa
Remove the battery by sliding the latch to the left and pulling the battery up.
Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
Quase terminado!
Conclusão
