Ir para o conteúdo principal
Alienware M14xR2 Status-Light Board Replacement
O que você precisa
  1. Alienware M14xR2 Status-Light Board Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Status-Light Board Replacement: passo 2, imagem 1 %32 Alienware M14xR2 Status-Light Board Replacement: passo 2, imagem 2 %32 Alienware M14xR2 Status-Light Board Replacement: passo 2, imagem 3 %32
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Status-Light Board Replacement: passo 3, imagem 1 %32
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Status-Light Board Replacement: passo 4, imagem 1 %32 Alienware M14xR2 Status-Light Board Replacement: passo 4, imagem 2 %32 Alienware M14xR2 Status-Light Board Replacement: passo 4, imagem 3 %32
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: passo 5, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Turn the palm-rest assembly over.
  6. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: passo 6, imagem 1 %32
    • Note the routing of status-light board cable and remove the cable from the routing guides.
    • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
  7. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: passo 7, imagem 1 %32
  8. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: passo 8, imagem 1 %32
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  9. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: passo 9, imagem 1 %32
    • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
  10. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: passo 10, imagem 1 %32
    • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
  11. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: passo 11, imagem 1 %32
    • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
  12. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: passo 12, imagem 1 %32
    • Replace the screw that secures the status-light board to the palm-rest assembly.
  13. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: passo 13, imagem 1 %32
  14. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: passo 14, imagem 1 %32
    • Route the status-light board cable through the routing guides on the palm-rest assembly.
Conclusão
Terrence15
Membro desde: 12/18/17
79.309 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
Um comentário
Völliges Durcheinander und unvollständig
Robert Fleischhauer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 686
