Ir para o conteúdo principal
Alienware M11xR2 Coin-Cell Battery Replacement
O que você precisa
  1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: passo 2, imagem 1 %32
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: passo 3, imagem 1 %32
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: passo 4, imagem 1 %32
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: passo 5, imagem 1 %32
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: passo 6, imagem 1 %32
    • Disconnect the coin-cell battery cable from the connector on the system board.
  7. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: passo 7, imagem 1 %32
    • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  8. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: passo 8, imagem 1 %32
    • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  9. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: passo 9, imagem 1 %32
    • Connect the coin-cell battery cable to the connector on the system board.
Conclusão
3 outras pessoas executaram este guia.
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 43
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 562
