Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we will be showing you how to remove and replace the Battery Pack.
O que você precisa
Loosen the eight captive screws that secure the base cover to the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
Tighten the eight screws that secure the base cover to the computer base.
Remove the two screws that secure the battery pack to the computer base.
Disconnect the battery pack cable from the connector on the system board.
Using the pull-tab, lift the battery pack off the computer base.
Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
Connect the battery pack cable to the connector on the system board.
3 outras pessoas executaram este guia.
