Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Lift the hard drive away from the hard-drive bracket.
Place the NEW hard drive in the hard-drive bracket.
Replace the four screws that secure the hard-drive to the hard-drive bracket.
Place the hard-drive assembly in the computer base.
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
