Ir para o conteúdo principal
Alienware Aurora M9700 RAM Replacement
O que você precisa
  1. Alienware Aurora M9700 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Turn the laptop over so the bottom of the device is facing upward.
  2. Alienware Aurora M9700 RAM Replacement: passo 2, imagem 1 %32 Alienware Aurora M9700 RAM Replacement: passo 2, imagem 2 %32 Alienware Aurora M9700 RAM Replacement: passo 2, imagem 3 %32
    • Remove the battery by unlocking the lock.
  3. Alienware Aurora M9700 RAM Replacement: passo 3, imagem 1 %32 Alienware Aurora M9700 RAM Replacement: passo 3, imagem 2 %32 Alienware Aurora M9700 RAM Replacement: passo 3, imagem 3 %32
    • Located on the top right corner, find the 4 screws that are holding the back plate to the laptop.
    • Once the screws are removed insert the spudger on the right side and pry upwards to lift the plate to remove the plate.
  4. Alienware Aurora M9700 RAM Replacement: passo 4, imagem 1 %32 Alienware Aurora M9700 RAM Replacement: passo 4, imagem 2 %32 Alienware Aurora M9700 RAM Replacement: passo 4, imagem 3 %32
    • Lift the back plate of the laptop to expose the RAM.
    • Locate the RAM near the bottom edge of the top portion.
  5. Alienware Aurora M9700 RAM Replacement: passo 5, imagem 1 %32 Alienware Aurora M9700 RAM Replacement: passo 5, imagem 2 %32 Alienware Aurora M9700 RAM Replacement: passo 5, imagem 3 %32
    • The RAM is secured by two aluminum locks on each side.
    • Pull the left-lock to the left to release the RAM.
    • While still holding the left hinge, pull the right-lock to the right and the RAM will be released.
  6. Alienware Aurora M9700 RAM Replacement: passo 6, imagem 1 %32 Alienware Aurora M9700 RAM Replacement: passo 6, imagem 2 %32 Alienware Aurora M9700 RAM Replacement: passo 6, imagem 3 %32
    • Once the RAM is released, pull the RAM out.
    • There may be a second RAM located below the first one, if so repeat step 5.
    • After both RAMS are removed you can now replace or upgrade the RAM.
Conclusão
Jasmine Anchondo
Membro desde: 10/09/18
679 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 317
