Ir para o conteúdo principal
Alienware Aurora M9700 Hard Drive Replacement
O que você precisa
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: passo 2, imagem 1 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 2, imagem 2 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 2, imagem 3 %32
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: passo 3, imagem 1 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 3, imagem 2 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 3, imagem 3 %32
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: passo 4, imagem 1 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 4, imagem 2 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 4, imagem 3 %32
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: passo 5, imagem 1 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 5, imagem 2 %32 Alienware Aurora M9700 Hard Drive Replacement: passo 5, imagem 3 %32
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
Conclusão
Jasmine Anchondo
Membro desde: 10/09/18
679 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 411
