Ir para o conteúdo principal
Alienware Aurora M9700 Camera Replacement
O que você precisa
  1. Alienware Aurora M9700 Camera Replacement, Camera: passo 1, imagem 1 %32
    • Open the device so the main screen is facing forward.
    • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
    • Locate the 8 screws around the perimeter of the screen and unscrew them.
  2. Alienware Aurora M9700 Camera Replacement: passo 2, imagem 1 %32 Alienware Aurora M9700 Camera Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
    • Slide the lock to the right when removing the display frame.
    • Remove the frame display.
  3. Alienware Aurora M9700 Camera Replacement: passo 3, imagem 1 %32 Alienware Aurora M9700 Camera Replacement: passo 3, imagem 2 %32
    • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
    • Remove the two screws freeing the camera of the brackets holding it in place.
    • Pry the camera upward from its designated location using the metal spudger.
  4. Alienware Aurora M9700 Camera Replacement: passo 4, imagem 1 %32 Alienware Aurora M9700 Camera Replacement: passo 4, imagem 2 %32
    • Unplug the wire connection between the camera and the laptop.
Conclusão
Jasmine Anchondo
Membro desde: 10/09/18
679 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 177
