Introdução
The following procedure will guide the reader through replacing the solid state drive (SSD) in the Alienware Alpha R2 desktop computer. The storage drive of a computer is where a computer’s operating system is stored, along with all of the data on the computer. Whenever a computer is booted, the operating system is loaded from the storage drive.
You might be wondering, “why replace a solid state drive”? If your computer is constantly freezing or if there is a long interval of a blank screen when turning on your computer, it is probably due to a faulty storage drive. Fortunately, a replacement solid state drive can return your computer back to its former glory, making your computer boot and function much faster, and saving you a lot time and frustration.
Replacing a faulty drive with a functional solid state drive will increase the speed of your computer, as it will be able to both load the OS faster, resulting in a quicker boot time, and also access files faster, resulting in a snappier response time overall.
O que você precisa
Unplug the device.
Press the power button and hold it for approximately 10 seconds to discharge any power stored in the device.
Congratulations, You have now successfully upgraded your Hard Drive Disk to a Solid State Drive. To reassemble, follow the steps in reverse order.
