Introdução
This guide will teach you how to remove the wi-fi card.
O que você precisa
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Uma outra pessoa concluiu este guia.
Um comentário
What is the logic for removing the HHD prior to removing the WIFI card?
