Ir para o conteúdo principal
Alienware 17 R4 Wi-Fi Card Replacement
O que você precisa
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: passo 1, imagem 1 %32
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Alienware 17 R4 Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: passo 3, imagem 1 %32
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Alienware 17 R4 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: passo 5, imagem 1 %32 Alienware 17 R4 Wi-Fi Card Replacement: passo 5, imagem 2 %32 Alienware 17 R4 Wi-Fi Card Replacement: passo 5, imagem 3 %32
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Alienware 17 R4 Wi-Fi Card Replacement: passo 6, imagem 2 %32
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Conclusão
Uma outra pessoa concluiu este guia.
Hector Mendez III
Membro desde: 09/11/17
1.280 Reputação
Autoria de 8 guias
Equipe
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
Membros da 4
Autoria de 9 guias
Um comentário
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 70
Duração total: 4,684
