Ir para o conteúdo principal
Alienware 17 R4 Solid State Drive (SSD) Replacement
O que você precisa
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: passo 1, imagem 1 %32
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 2, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 2, imagem 2 %32
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, imagem 2 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): passo 3, imagem 3 %32
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, imagem 2 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 4, imagem 3 %32
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, imagem 2 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 5, imagem 3 %32
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 6, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 6, imagem 2 %32
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: passo 7, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: passo 7, imagem 2 %32
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 8, imagem 1 %32 Alienware 17 R4 Solid State Drive (SSD) Replacement: passo 8, imagem 2 %32
    • Slide the solid state drive towards yourself to prevent damage to the card.
Conclusão
3 outras pessoas executaram este guia.
Hector Mendez III
Membro desde: 09/11/17
1.352 Reputação
Autoria de 8 guias
Equipe
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Membros
Autoria de 9 guias
1Comentário do guia
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 7,370
