Ir para o conteúdo principal
Alienware 17 R3 Display Replacement
O que você precisa
  1. Alienware 17 R3 Display Replacement, Display: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Flip the computer upside down.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Display Replacement: passo 2, imagem 1 %32
    • Unscrew and remove the two 4mm Phillips screws from cover.
  3. Alienware 17 R3 Display Replacement: passo 3, imagem 1 %32
    • Pull up and slide cover off.
  4. Alienware 17 R3 Display Replacement: passo 4, imagem 1 %32 Alienware 17 R3 Display Replacement: passo 4, imagem 2 %32
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Display Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, pull display casing away from main body.
  6. Alienware 17 R3 Display Replacement: passo 6, imagem 1 %32
    • Unscrew and remove the two 2mm Phillips screws from the bottom of the display.
  7. Alienware 17 R3 Display Replacement: passo 7, imagem 1 %32
    • Disconnect plugs connecting the display to the main body.
  8. Alienware 17 R3 Display Replacement: passo 8, imagem 1 %32
    • Lift display out.
Conclusão
6 outras pessoas executaram este guia.
Equipe
UW Tacoma, Team 1-1, Rose Winter 2017 Membro de UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
Membros da 3
Autoria de 5 guias
Um comentário
The best and easiest way to replace the screen!
Jhun Calvin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 4,278
