Ir para o conteúdo principal
Alienware 17 R2 Base Panel Replacement
O que você precisa
  1. Alienware 17 R2 Base Panel Replacement, Close the Display: passo 2, imagem 1 %32
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
  2. Alienware 17 R2 Base Panel Replacement, Loosen Screws: passo 3, imagem 1 %32
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Alienware 17 R2 Base Panel Replacement, Releasing Tabs: passo 4, imagem 1 %32
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Alienware 17 R2 Base Panel Replacement, Remove Base Panel: passo 5, imagem 1 %32
    • Slide and remove the base panel from the computer base.
  5. Alienware 17 R2 Base Panel Replacement, Disconnect Battery Cable: passo 6, imagem 1 %32
    • Disconnect the Battery cable from the system board.
    • Turn the computer over.
    • Press and hold power button for 5 seconds to ground the system board.
  6. Alienware 17 R2 Base Panel Replacement, Battery Cable: passo 9, imagem 1 %32
    • Connect the battery cable to the system board.
  7. Alienware 17 R2 Base Panel Replacement, Tighten Screws: passo 10, imagem 1 %32
    • Tighten the captive screws that secure the base panel to the computer base.
Conclusão
Terrence15
Membro desde: 12/18/17
80.065 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.002 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 26
Últimos 30 dias: 57
Ao todo: 1,168
