Ir para o conteúdo principal
Alcatel Pop 4 Plus Rear Camera Replacement
O que você precisa
  1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Rear Camera Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Rear Camera Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Rear Camera Replacement: passo 2, imagem 2 %32
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Rear Camera Replacement: passo 3, imagem 1 %32
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Rear Camera Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Rear Camera Replacement: passo 4, imagem 2 %32
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Rear Camera Replacement, Rear Camera: passo 5, imagem 1 %32
    • Use the flat end of the spudger tool to remove the connector.
  6. Alcatel Pop 4 Plus Rear Camera Replacement: passo 6, imagem 1 %32
    • Pry out the camera with the pointy end of the spudger tool.
Conclusão
Maalik Poleon
Membro desde: 01/25/18
202 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro de USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 269
