Ir para o conteúdo principal
Alcatel Pop 4 Plus Motherboard Replacement
O que você precisa
  1. Alcatel Pop 4 Plus Motherboard Replacement, Battery: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Motherboard Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement: passo 2, imagem 2 %32
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Motherboard Replacement: passo 3, imagem 1 %32
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Motherboard Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement: passo 4, imagem 2 %32
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Motherboard Replacement: passo 6, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement: passo 6, imagem 2 %32
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Motherboard Replacement: passo 7, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement: passo 7, imagem 2 %32
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Motherboard Replacement: passo 8, imagem 1 %32 Alcatel Pop 4 Plus Motherboard Replacement: passo 8, imagem 2 %32
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Motherboard Replacement: passo 9, imagem 1 %32
    • Use the flat end of the spudger to pry off the motherboard.
Conclusão
Pieter Molenaar
Membro desde: 01/25/18
253 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro de USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
Membros da 4
Autoria de 12 guias
Um comentário
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
NINJA WARRIORS - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 947
