Ir para o conteúdo principal
Alcatel Pop 4 Plus Front Camera Replacement
O que você precisa
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
    Pergunte ao FixBot
    Comentar
  2. Alcatel Pop 4 Plus Front Camera Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement: passo 2, imagem 2 %32
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
    Pergunte ao FixBot
    Comentar
  3. Alcatel Pop 4 Plus Front Camera Replacement: passo 3, imagem 1 %32
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
    Pergunte ao FixBot
    Comentar
  4. Alcatel Pop 4 Plus Front Camera Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement: passo 4, imagem 2 %32
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
    Pergunte ao FixBot
    Comentar
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: passo 5, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: passo 5, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
    Pergunte ao FixBot
    Comentar
  6. Alcatel Pop 4 Plus Front Camera Replacement: passo 6, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement: passo 6, imagem 2 %32
    • Use the flat end of a spudger to disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. Alcatel Pop 4 Plus Front Camera Replacement: passo 7, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement: passo 7, imagem 2 %32
    • Using the flat end of the spudger to disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Alcatel Pop 4 Plus Front Camera Replacement: passo 8, imagem 1 %32 Alcatel Pop 4 Plus Front Camera Replacement: passo 8, imagem 2 %32
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Alcatel Pop 4 Plus Front Camera Replacement: passo 9, imagem 1 %32
    • Use the flat end of the spudger to pry off the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: passo 10, imagem 1 %32
    • Disconnect the camera from the motherboard using the flattened of a spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
peter achanccaray
Membro desde: 01/25/18
123 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro de USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 48
Ao todo: 577
