Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
_______________ Video tutorial: _______________
Vídeo de Apresentação
  1. The Battery / Back cover is secured to the main frame by plastic clips. Use a plastic tool to remove it. Use a plastic tool to remove it.
    • The Battery / Back cover is secured to the main frame by plastic clips.
    • Use a plastic tool to remove it.
  2. Use a Phillips screwdriver and remove the two screws secured the battery connector shield. With tweezers careful remove the battery connector shield. With tweezers careful remove the battery connector shield.
    • Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
    • With tweezers careful remove the battery connector shield.
  3. Disconnect the battery cable.
    • Disconnect the battery cable.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Disconnect: Touchscreen flex cable
    • Disconnect:
    • Touchscreen flex cable
    • Main Camera flex cable
    • LCD flex cable
    • Vibra-motor
    • New line.Remove 7x Phillips screws.
  6. Careful unstuck the Volume buttons flex cable and the Power button flex cable. Use a plastic tool and remove the Logic board. Use a plastic tool and remove the Logic board.
    • Careful unstuck the Volume buttons flex cable and the Power button flex cable.
    • Use a plastic tool and remove the Logic board.
  7. Use a hair dryer to warm the glass to soften the adhesive. Use a knife or tool with a sharp edge and start the separating the glass from the frame. Continue with a plastic tool.
    • Use a hair dryer to warm the glass to soften the adhesive.
    • Use a knife or tool with a sharp edge and start the separating the glass from the frame.
    • Continue with a plastic tool.
  8. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  9. Clean the frame and install a new adhesive tape. Install the touch screen. Install the touch screen.
    • Clean the frame and install a new adhesive tape.
    • Install the touch screen.
Conclusão
ZFix
Membro desde: 09-12-2013
168.896 Reputação
306 Guias de autoria
equipe
Master Techs Membro de Master Techs
Community
292 Membros
833 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,339
