Ir para o conteúdo principal
Alcatel OneTouch Pop Icon Battery Replacement
O que você precisa
  1. Alcatel OneTouch Pop Icon Battery Replacement, Battery: passo 1, imagem 1 %32
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Battery Replacement: passo 2, imagem 1 %32 Alcatel OneTouch Pop Icon Battery Replacement: passo 2, imagem 2 %32
    • Use your thumbnail to lift the battery from the phone.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 40
Ao todo: 2,661
