Ir para o conteúdo principal
Alcatel OneTouch Evolve Battery Removal
O que você precisa
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: passo 1, imagem 1 %32
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    Pergunte ao FixBot
    Comentar
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, imagem 1 %32 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, imagem 2 %32 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: passo 2, imagem 3 %32
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    Pergunte ao FixBot
    Comentar
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: passo 3, imagem 1 %32
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    Pergunte ao FixBot
    Comentar
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: passo 4, imagem 1 %32 Alcatel OneTouch Evolve Battery Removal, Removing the battery: passo 4, imagem 2 %32
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Brendan Egan
Membro desde: 10/28/14
2.491 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-5, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Membros
Autoria de 12 guias
5Comentários do guia
Thanks 4 the info.
dennisp1964 - Responder Compartilhar
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Responder Compartilhar
please replay
Thank you very much!
Kath B - Responder Compartilhar
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 42
Ao todo: 10,518
