Ir para o conteúdo principal
Alcatel OneTouch Elevate Screen Replacement
O que você precisa
  1. Alcatel OneTouch Elevate Screen Replacement, Battery: passo 1, imagem 1 %32 Alcatel OneTouch Elevate Screen Replacement, Battery: passo 1, imagem 2 %32 Alcatel OneTouch Elevate Screen Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate Screen Replacement: passo 2, imagem 1 %32 Alcatel OneTouch Elevate Screen Replacement: passo 2, imagem 2 %32 Alcatel OneTouch Elevate Screen Replacement: passo 2, imagem 3 %32
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate Screen Replacement, Screen: passo 3, imagem 1 %32 Alcatel OneTouch Elevate Screen Replacement, Screen: passo 3, imagem 2 %32
    • Remove back plate from phone.
    • Locate indent on corner of phone
    • Use pry tool to take off back of phone.
  4. Alcatel OneTouch Elevate Screen Replacement: passo 4, imagem 1 %32
    • Find a very slim object to slide in between glass and phone.
    • Pry it off little by little until you are able to take it off.
  5. Alcatel OneTouch Elevate Screen Replacement: passo 5, imagem 1 %32
    • After screen is off apply new screen
    • Make sure cable is in correct place after putting glass back on.
    • Test to make sure it works.
Conclusão
Jemier Virtue
Membro desde: 02/08/18
97 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 188
