Ir para o conteúdo principal
Alcatel OneTouch Elevate SIM Card Replacement
O que você precisa
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, imagem 1 %32 Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, imagem 2 %32 Alcatel OneTouch Elevate SIM Card Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: passo 2, imagem 1 %32 Alcatel OneTouch Elevate SIM Card Replacement: passo 2, imagem 2 %32 Alcatel OneTouch Elevate SIM Card Replacement: passo 2, imagem 3 %32
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: passo 3, imagem 1 %32 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: passo 3, imagem 2 %32
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: passo 4, imagem 1 %32
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: passo 5, imagem 1 %32 Alcatel OneTouch Elevate SIM Card Replacement: passo 5, imagem 2 %32
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 722
