Pular para o conteúdo principal
Introdução
This guide will walk you through the steps on changing your phones SD card with guided pictures to help at every stage
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Locate the small indent on the lower left corner. Use your fingers or a small plastic opening tool to lift the back cover off. Use your fingers or a small plastic opening tool to lift the back cover off.
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Locate the indent between the battery and your phone. Use your finger or a small plastic opening tool to lift the battery free. Use your finger or a small plastic opening tool to lift the battery free.
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Apple Watch Kits
    Screen and battery repairs just got easier.
    Comprar agora
    Apple Watch Kits
    Comprar agora
  4. Locate the SD card slot at the top left of the phone. If an SD card is not present, you can skip to step 4
    • Locate the SD card slot at the top left of the phone.
    • If an SD card is not present, you can skip to step 4
  5. The SD card will have an indent at the top, use this to carefully pull the card from the slot.
    • The SD card will have an indent at the top, use this to carefully pull the card from the slot.
  6. Grab the new SD card making sure not to touch the metallic area. With the metallic patch facing down, insert the card into the slot.
    • Grab the new SD card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Jorge
Membro desde: 08-02-2018
161 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 93
