Introdução
If you are experiencing a problem connecting to either WIFI or cellular data, you could have a faulty WIFI antenna. This guide will show you the simple steps to replace it.
O que você precisa
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
Using the tweezers, pull the WIFI Antenna away from the motherboard and the wireless card.
Uma outra pessoa concluiu este guia.
