Introdução
This guide will help you in replacing the front camera of an Alcatel One Touch Evolve 2 phone.
O que você precisa
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
3 outras pessoas executaram este guia.
