Ir para o conteúdo principal
Alcatel One Touch Elevate (5017B) Motherboard Replacement
O que você precisa
  1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: passo 1, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: passo 1, imagem 2 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 2, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 2, imagem 2 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 2, imagem 3 %32
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: passo 3, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: passo 3, imagem 2 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: passo 3, imagem 3 %32
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 4, imagem 1 %32
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 5, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 5, imagem 2 %32
    • Disconnect the camera from the mother board with your prying tool.
  6. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 6, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 6, imagem 2 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 6, imagem 3 %32
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 7, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 7, imagem 2 %32
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 8, imagem 1 %32
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 9, imagem 1 %32 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 9, imagem 2 %32
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: passo 10, imagem 1 %32
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 270
