Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Use this guide to replace the Motherboard in Alcatel Jitterbug Smart.
It's also an useful guide to help you to replace headphone Jack, camera and charging port.
  1. Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone. Lift open case by the corner nearest the divot and remove it from the phone.
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Remove 13 1mm JIS screws with JIS #000 Screwdriver. Remove 13 1mm JIS screws with JIS #000 Screwdriver. Remove 13 1mm JIS screws with JIS #000 Screwdriver.
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Gently pry off the Mid frame from the phone using a Metal Spudger. Gently pry off the Mid frame from the phone using a Metal Spudger.
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Use a pair of tweezers to pull the battery connector from its port. Be careful not to tear the battery from its connection.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone. Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone. Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Use a pair of tweezers to pull the black ribbon connector from its port. Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly. The motherboard will freely remove.
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
Conclusão
Gavin Le
Membro desde: 13/02/2018
367 Reputação
3 Guias de autoria
Equipe
USF Tampa, Team S11-G4, Cheng Spring 2018 Membro de USF Tampa, Team S11-G4, Cheng Spring 2018
USFT-CHENG-S18S11G4
4 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 154
