Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
Lift open case by the corner nearest the divot and remove it from the phone.
Remove 13 1mm JIS screws with JIS #000 Screwdriver.
Gently pry off the Mid frame from the phone using a Metal Spudger.
Use a pair of tweezers to pull the battery connector from its port.
7 outras pessoas executaram este guia.
4 comentários
After reading my user guide, I searched how to replace a battery on a Jitterbug Smart2 and had several hits. I connected with this one: Alcatel Jitterbug Smart Battery Replacement 104708#. I see this is the site you have, so I began to follow instructions. When I took the back off of my phone, I saw it looks different from the one you show. Also, mine says this is a non-removeable battery. What do I do now?
I just called Great Call. They told me the battery is not replaceable. I’ll risk it anyway: What’s the point of a cordless phone that doesn’t work without a cord?
I followed your directions step by step to remove the battery but on my Jitterbug Smart I, there are only 12 screws instead of 13! Your photo shows a screw in the middle near the camera lens but on my phone, that screw does not exist and the word void is printed in it’s place where the screw would be. Because of this, I was unable to remove the mid frame to get access to the battery. It seems to be stuck where the lens is situated making it impossible to remove and I don’t want to break it off.
Jitterbug Smart 2 has a NON REMOVEABLE BATTERY. These bogus instructions sell a lot of U$ELE$$ batteries
