Ir para o conteúdo principal
Alcatel IdealXCITE Rear Speaker Replacement
O que você precisa
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: passo 1, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement, Battery: passo 1, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: passo 2, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 2, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 2, imagem 3 %32
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: passo 3, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement, Antenna: passo 3, imagem 2 %32
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: passo 4, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 4, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 4, imagem 3 %32
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: passo 5, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: passo 5, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: passo 5, imagem 3 %32
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: passo 6, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 6, imagem 2 %32
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: passo 7, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 7, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 7, imagem 3 %32
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: passo 8, imagem 1 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 8, imagem 2 %32 Alcatel IdealXCITE Rear Speaker Replacement: passo 8, imagem 3 %32
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
Conclusão
Franklin Froehlich
Membro desde: 03/07/19
427 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 328
