Ir para o conteúdo principal
Alcatel IdealXCITE Battery Replacement
O que você precisa
  1. Alcatel IdealXCITE Battery Replacement, Battery: passo 1, imagem 1 %32 Alcatel IdealXCITE Battery Replacement, Battery: passo 1, imagem 2 %32 Alcatel IdealXCITE Battery Replacement, Battery: passo 1, imagem 3 %32
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Battery Replacement: passo 2, imagem 1 %32 Alcatel IdealXCITE Battery Replacement: passo 2, imagem 2 %32 Alcatel IdealXCITE Battery Replacement: passo 2, imagem 3 %32
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
Conclusão
In order to reassemble your device, follow the instructions in reverse order.
Franklin Froehlich
Membro desde: 03/07/19
427 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 446
