Ir para o conteúdo principal
Alcatel Fierce 4 Earpiece Speaker Replacement
O que você precisa
  1. Alcatel Fierce 4 Earpiece Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Earpiece Speaker Replacement: passo 2, imagem 1 %32 Alcatel Fierce 4 Earpiece Speaker Replacement: passo 2, imagem 2 %32
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Earpiece Speaker Replacement: passo 3, imagem 1 %32
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Earpiece Speaker Replacement: passo 4, imagem 1 %32 Alcatel Fierce 4 Earpiece Speaker Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Earpiece Speaker Replacement: passo 5, imagem 1 %32
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Earpiece Speaker Replacement: passo 6, imagem 1 %32
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Alcatel Fierce 4 Earpiece Speaker Replacement, Earpiece Speaker: passo 7, imagem 1 %32 Alcatel Fierce 4 Earpiece Speaker Replacement, Earpiece Speaker: passo 7, imagem 2 %32 Alcatel Fierce 4 Earpiece Speaker Replacement, Earpiece Speaker: passo 7, imagem 3 %32
    • Use tweezers to pull the earpiece speaker out of the phone.
Conclusão
Rawan
Membro desde: 02/22/18
644 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G2, Cagle Spring 2018 Membro de USF Tampa, Team S1-G2, Cagle Spring 2018
USFT-CAGLE-S18S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 144
