Ir para o conteúdo principal
Alcatel Fierce 4 Battery Replacement
O que você precisa
  1. Alcatel Fierce 4 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Battery Replacement: passo 2, imagem 1 %32 Alcatel Fierce 4 Battery Replacement: passo 2, imagem 2 %32
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Battery Replacement: passo 3, imagem 1 %32
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Battery Replacement: passo 4, imagem 1 %32 Alcatel Fierce 4 Battery Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Battery Replacement: passo 5, imagem 1 %32
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Battery Replacement: passo 6, imagem 1 %32
    • Carefully pry up the battery with a plastic opening tool, or your hands.
Conclusão
Equipe
USF Tampa, Team S1-G2, Cagle Spring 2018 Membro de USF Tampa, Team S1-G2, Cagle Spring 2018
USFT-CAGLE-S18S1G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,849
