Ir para o conteúdo principal
Akko 3068B Battery Replacement
O que você precisa
  1. Akko 3068B Battery Replacement, Battery: passo 1, imagem 1 %32 Akko 3068B Battery Replacement, Battery: passo 1, imagem 2 %32 Akko 3068B Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the USB-C cable from the keyboard.
    • Turn off keyboard using the switch on the back.
  2. Akko 3068B Battery Replacement: passo 2, imagem 1 %32 Akko 3068B Battery Replacement: passo 2, imagem 2 %32
    • Remove the keycaps using a keycap puller.
    • Removing them without thought can accidentally damage the switches on the keyboard. Proceed with caution.
  3. Akko 3068B Battery Replacement: passo 3, imagem 1 %32 Akko 3068B Battery Replacement: passo 3, imagem 2 %32 Akko 3068B Battery Replacement: passo 3, imagem 3 %32
    • Remove the three screws holding the PCB in place using a Phillips #00 screwdriver.
  4. Akko 3068B Battery Replacement: passo 4, imagem 1 %32 Akko 3068B Battery Replacement: passo 4, imagem 2 %32 Akko 3068B Battery Replacement: passo 4, imagem 3 %32
    • Insert a card to pry open the casing on the keyboard.
    • When prying open the casing, beware that there are clips that lock the casing to the keyboard. Make sure not to break them or the casing will not lock properly afterwards.
    • A small clear piece might fall out near the keyboard lights; make sure to place it back when reassembling.
  5. Akko 3068B Battery Replacement: passo 5, imagem 1 %32 Akko 3068B Battery Replacement: passo 5, imagem 2 %32 Akko 3068B Battery Replacement: passo 5, imagem 3 %32
    • Careful! If the keyboard is old, the PCB might just fall out.
    • Slowly lift up the PCB as there is a connector on the back; make sure not to rip it apart.
  6. Akko 3068B Battery Replacement: passo 6, imagem 1 %32
    • Lift up the sound proof foam.
  7. Akko 3068B Battery Replacement: passo 7, imagem 1 %32 Akko 3068B Battery Replacement: passo 7, imagem 2 %32
    • Slowly wiggle the battery wire out of its connector on the motherboard.
    • If too much strength is applied, you can rip off the port.
  8. Akko 3068B Battery Replacement: passo 8, imagem 1 %32
    • Remove the battery from the keyboard.
    • Make sure that the new battery is compatible. This is a 1800 mah battery.
Conclusão
Dylan Tran
Membro desde: 01/23/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 60
Duração total: 165
