Ir para o conteúdo principal
Airox Legendair Battery Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: passo 1, imagem 1 %32
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: passo 3, imagem 1 %32
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: passo 4, imagem 1 %32
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: passo 6, imagem 1 %32
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: passo 7, imagem 1 %32
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: passo 8, imagem 1 %32
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: passo 9, imagem 1 %32
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: passo 10, imagem 1 %32
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: passo 11, imagem 1 %32
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
Conclusão
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
Membro desde: 04/09/20
174 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G15, Paton Spring 2020 Membro de Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 337
